Alpine rw12-d4 making weird noise.
  • 4
Hi my alpine rw12-d4 started making this noise shortly after I got it last June. If anyone has any idea what this noise is that would be great before I take it back under warranty.
It sounds like it's hitting xmax or is at least under dampened. That can happen due to fatigue in ported or vented enclosures and can happen due to an air leak in a sealed enclosure. It could also happen due to a hole in the cone/surround. That's assuming no settings have changed between not hearing it and now hearing it on the same songs. It could also be something like a dust cap falling off and interacting with the back side of the cone inside the box, something resonating against the box, your car resonating from that specific note... Quite a few things. If it's the driver making that sound in a clean box then the box needs more dampening to keep the driver from experiencing so much unproductive excursion.
If you did change settings then you should probably reassess the new ones.
Is your amp well matched to your subwoofer? Is it more powerful? Did you set up the amp properly to not clip?
Had that happen on a Fosgate p2. It turned out that the "dust cap" began to unglue at one spot. The entire cone area of your sub is the dust cap. I tried gluing the edge, but it proved too difficult getting under that rim. Ended up scrapping it. I would do the warranty.
I’ve inspected the sub multiple times and can’t for the life of me see anything that looks bad. It still pounds like brand new but on certain songs and certain notes the sub just sounds like trash if I have the volume up. The way that noise plays through the box is terrible. Anyone got any good quality loud subs they recommend? I’m running a PDR-m65 alpine amp with a 1.5 net cu.ft box. Was thinking a JL W3
Thats a decent sub.. Why not try a properly Tuned Enclosure before you go swapping subs??That Type R needs to be in a larger enclosure to perform. That 1.5 is more for like a 10" sub. Try building one or buy one tuned for that sub
You think going to 1.7 like recommended would make a huge difference? I love the sub it pounds way harder than the type s 12”, just thrown off by the weird sound as the type s never made it in quite a small wedge box and still pounded
By inspect do you also mean the backside? I think the dust cap is a pretty likely culprit. As 1aespinoza mentioned it could still be attached but only weakly causing it to slap the hard plastic against the hard magnet which would sound horrible like that. In an undersized box I wouldn't expect mechanical noise like that unless there's an air leak or the port is too large/came unglued. Try playing it outside of the box (low volume) to see if you can narrow down what part the noise is coming from exactly.
Yes I’ve had it out if the box and still puts off the sound, someone told me it’s bottoming out when outside the box but I don’t understand why it would make the same sound while inside the box. Subs recommended for a 1.7 cu ft box and mine is 1.5 so not sure if that would make a huge difference.
It will bottom out outside of the box, but only if you turn up the volume. If it's doing it when the cone is barely moving then you may be looking at something scratching or bouncing around either inside the voice coil or maybe stuck on the spider. If it's the dust cap resonating then I don't think it would do so outside of the box, so maybe that rules that out. I think in order to be sure you should setup your amp with a test tone and a multimeter. If you're not exceeding the capacity of the speaker in the box and you're still experiencing noise then do the warranty return.
Recommended enclosure is always key to the subs performance, environment, location ect., Yet, most of us experience out of the box for getting the Max performance from trial and error. Properly tumed enclosure is what you need.Do you have tools and time and a little patience?Follow directions? Approx. $100- 150 Bucks? If so you can make your own in a couple days.If you want a properly Tuned and Custom enclosure, just buy one.
Or buy a custom Tuned enclosure
Send it in under your warranty.Sounds like you are going to have an issue with a coil. Id let them know its been doing this from day 1. Id still build a properly tuned enclosure for it.Ported will give you some really nice results with that Type R
These are just some examples for you and suggestions to get that sub to perform to its potential
Hey, just for shits and giggles try wrapping a sock around the junction. That is where the cone, spider and voice coil are glued together. If the ca glue is cracking, it will give you that sound on your video clip. I fixed an issue like that on one of my first subwoofers (freebie) in Jr. High. I tied shoe laces around that junction and bumped it on a home stereo for quite some time.
LOL!! YES!! Shoe laces.Got ta Luv It!!
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
110
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
7
362
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
Josh49
CarAudio.com Newbie
Josh49
Ontario, Canada
audiobaun
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
