Alpine sub+amp set up help
  • 1
Karlman
Hey, this is my first post. I don't know a whole lot about subs and amps but I've heard that the alpine type x's are killer subwoofers so I wanna hook up my car with one of those.
I was wondering, I have the option between putting in two type x's powered by a mrx-m110, or one type x powered by a pdx 1.1000. Both setups will probably cost be about the same amount, I'm just wondering if the mrx-m110 will put out enough power to the two type x's to be significantly better than the one type x powered by the pdx-1.1000.
What do you guys think?
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
203
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
7
476
So far I have bought Kicker CWRT8D4 Subthump underseat enclosure for 8 LoopBack Harness from AIS 8 gauge Kicker wiring kit (Will run two 8 gauge...
13
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
Karlman
Karlman
Drumheller, AB
Karlman
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
