Altenators !&!%#%$!#@#@#*&
  • 4
Well then you need to figure out how much current you're drawing and try to supply it. If it killed a 200a, either that alt was junk or it was drawing way more than 200a. The answer seems pretty clear pal.
Current is drawn. It's not forced. If your amp draws it, it will put out 310 amps. Will that blow your fuse? Maybe after like 2 or 3 years at a constant 310 amps of draw //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
You have a blown cap in the amp more than likely. Had the same thing happen to a soundstream amp.
228
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
432
Booty & Beats
Booty & Beats
Johnston, Rhode Island, United States
Wingman0121
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
