alternator problem
blowthemup
My voltage is randomly jumping all over the place, 13-16v. I would say its the alternator going out but the alternator guy is saying it sounds like a battery problem. My XS power batteries are only two years old so im sure they got plenty of life left in them. Is it the batteries, is it the alternator? The alternator also makes a humming sound even when the car is off and parked/locked. Doesn't seem right to me especially since these problems didn't exists when the alternator was new and I haven't changed anything to create the problem.
What do you guys think, whats the bad piece in the equation?
Sounds like the regulator in the alt is bad
Thats what I was thinking also, I mentioned it and he said sounds like a common battery problem. I keep my batteries on a charger quite frequently and there not that old so I dont think its them. How hard is it to change the voltage regulator in one of these things? Would going with an external voltage regulator be more reliable?
Yeah I'd say the regulator as well. When my alt regulator was going out it was doing the same thing. That you described. At idle I was at like 14.5v and at 2-3,000 rpms it would jump up to 17v.
Does anyone else with a Singer Alternator have any noise coming from it when the car is off/key out of ignition. Gonna try and get some video of the voltage jumping around and maybe the noises its making if my phone will pick it up.
Sorry about the bad video quality, filming/driving stick inst easy but you can make out the voltage just fine.
voltage jumping around https://www.youtube.com/watch?v=f9uPs-ScpZU
noisy alternator at idle https://www.youtube.com/watch?v=GjQd_BJ5OGM
BUMP....updated with videos!!!! Thanks for the help guys and any opinions are appreciated //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
that noise is the resistance a high output alternator has that would usually not be heard from stock as it couldnt make that power at idle. the noise is resistance in the stator against the spinning rotors magnetic field
the noise is normal. its pulsing in the video because his voltage fluctuation causes resistance change in the alternator causing swing in load on the engine.
And swinging load is normal? Cuz I feel like its not..
Sent from my SGH-T999 using Tapatalk
swinging load no, thats why i asked if you were referencing the noise when you asked how to fix it as the noise he asked about it normal
Hello I also have a question I want to buy 160ah lto, i.e. 4 banks but I have a stock alternator of 140 a and a maximum load of 14.9 do you think...
Okay cool bc I'm thinking about getting 5k amp and just wasn't sure if that battery would do but I appreciate all the help
18
I don't have one...but I check my voltage with a dmm once a week or so
12
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
blowthemup
blowthemup
North Carolina
garychurch84
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
