Alternator questions
  • 2
argenis69
SQ Bass Lover
844
NY, USA
I have a question about my car or alternator. 2002 Nissan Maxima, I have a permanent volt meter inside my car monitoring my electric status due to my audio install, I've noticed that when I'm on the highway at high speed or when at high idle, normally above 2,000 rpm, the voltage drops, below 12.6v and the battery and brake lights start to blink on and off on the dashboard, even with my radio and complete system off. What is happening?
Thanks.*
Same, only real bass heads or engineers understand you can't use power without making it. I went to the 240 alt when I did the winch and lights on...
14
This is really the only correct answer since we have no way to account for the other variables. If you're not talking about the same exact...
7
From what I've read, LiFePO4 works with lead acid, LTO does not. I have only personally tried LiFePO4. I personally can't justify the extra hassle...
Hello I also have a question I want to buy 160ah lto, i.e. 4 banks but I have a stock alternator of 140 a and a maximum load of 14.9 do you think...
argenis69
SQ Bass Lover
argenis69
NY, USA
mlstrass
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
