aluminum sub box?!?!
A guy at work was telling me he was going to try this out.........I only hope he completes it so I can laugh in his face when it's a fail. I'm sure if the metal were thick enough and very well braced and deadened it could work but that would be crazy expensive with no real benefit. The guy at work was talking about using thin steel
Aluminum enclosure can be awesome when done correctly. I think this is funkywaves(?).
get the sound of a trunk, without a trunk!
I would face the port and sub back. Even if you got a soft top, the rear gate will serve as a loading wall. I looked at the specs for the 10w6v3...
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
9
140
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
286
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
465
dutchmaster
dutchmaster
syracuse new york
pro-rabbit
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
