Ambulance needs Custom Speaker Setup!!!!
  • 2
TannerW
I'm looking to convert this ambulance into a party bus. I also need help with finding the locations for my speakers. At the end i will incxlude a list of my speakers i have. I hope the interior picture i uploaded shows. if not ill try again. I am willing to cut a few areas inside to mount speakers. I am excepting all advice including locations, wiring and anyrthing else. Thanks guys!
x6 Kicker DS693 6"x9" 3-Way Speakers
MTX Audio Terminator Series TNE212D 1,200-Watt Dual 12-Inch Sub Enclosure
BOSS Audio R2000M Riot 2000-watts Monoblock Class A/B 1 Channel 2-8 Ohm Stable Amplifier
Pioneer FHX-720BT 2-DIN CD Receiver
Have you thought about gutting it and starting over? What's your experience installing car audio equipment? If you want I can direct you to a shop in your area.
I've thought about hitting some of it but I want some room to store things for long trips. I've only done a few speaker jobs when I've replaced factory speakers. but none that include an amp or a completely new sound system
I guess I asked for that when I declared myself a noob. I mean the interior side of the firewall which is heat shielded with Lizard Skin.
19
I hope it ended up helping someone in here. I was right there on the Morels, but didn't need em, so I dropped out earlier than I would have, I...
14
I think the easiest path would be an electronic x-over. You will control all the frequencies from one unit, making for a cleaner and simpler...
Problem resolved - Found a scrap Astra that was fitted with that same unit. Salvaged the Display and original plugs and wired it up on the dining...
TannerW
TannerW
Dallas, TX
TannerW
