American bass vfl beast
  • 1
cal
AB VFL 350.4
Specs:
2 ohm Stereo or 4 ohm Mono Stable High power 4 Channel Full Range Amplifier
RMS power at 4 Ohm: 175W x 4ch
RMS power at 2 Ohm: 250W x 4ch
RMS power at 4 ohm Mono: 500W x 2ch
Low Level Input and Output
Frequency Response: 20Hz ~ 20KHz
Damping Factor: 300
Signal to Noise Ratio: 105db
Input Level: 6V ~ 0.2V
Variable High Pass Filter: 10Hz ~ 300Hz
X-Over Selector: HP/Full/BPF (Band Pass Works)
Variable Low Pass Filter: 10Hz ~ 300Hz
Fuse Rating: 140A External Fuses
FR-4 Double Sided Printed Circuit Board
High Quality Mold Type Power/Speaker Terminal
Dimensions (Inches)
Height: 2.25
Width: 9.75
Length: 20.75
new/open box. never been used,demod or installed . was going to run this with the vfl 1000.1 and plans changed . amp was outside so thats why it looks weird in pics.
385. shipped con u.s. only
Without better photos it's hard to really see anything. Based off of those it looks just fine. Grab a digital multimeter, set it to continuity...
9
  • Locked
Great amp. Ran on nothing lower than 13.9 volts ever. Adult owned and never abused. Looks: 8 of 10. A few scratches due to being used...
Yes, they are definitely beefy. I beat the snot out of this one to find it's limits and it took it rather well. For the abuse I put it through and...
Placed a pair in a an enclosure according to enclosure specs below on a Crescendo Skyway 3k and they seem to be doing very nice and really...
cal
cal
cal
Decebal
    Jun 10, 2024
