amp, 1500bdcp or similar
  • 2
Thats what I figured which is fine. You are familiar with box rise though, right? RMS ratings of amp are with dummy testers at a certain load without a box.. So say an amp that is rated 2000 RMS at 1 ohm, and amp actually puts out the 2000 RMS. Well, depends on the box but say you only get a box rise of 1.5 ohms while using this 2000 RMS at 1 ohm amp now you would have 1000 RMS to sub(s). So if you have two subs using this example thats 500 RMS to each sub, and if one sub it would see 1000 RMS..
143
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
341
6
465
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
751
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
550
corey0928
corey0928
Warren, MI
corey0928
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
