Amp Blowing 50A Fuse Under Hood With Hookup
Thank you very much, this is the most help I've gotten on the subject.
But I have been checking out this site called bcae1,com. there's a lot of info on there about this kind of thing so I plan on doing plenty of research and hopefully I will be able to learn the things I'd like to learn so I'm not completely helpless when something decides to fry on me.
Two subs, same issue, two LOC's same issue, seems to me that there is an issue upstream. Have you tested the amp disconnected from the signal...
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
251
6
431
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
727
Oz.Germolus
Roanoke, VA
Oz.Germolus
winkychevelle
    Jun 3, 2024
