amp choice for 2xAA mayhem
  • 5
Hey guys, so now i have bought 2xAA Mayhems 18s and am a little torn inbetween a few amps to choose from. Im in the Netherlands at the moment and have a few choices regarding amps.
1. 1xHifonics brx12000d (1x6000rms at 1ohm)
2. 1xGround zero gzpa1.6khcx (1x6000rms at 1ohm)
3. 2xMassive d8000 (1x3000rms at 1 ohm)
4. 2xPioneer PRS-D2000SPL (not sure the rms rating)
5. 2xGround zero gzpa 1.4000dxii (2400rms at 2ohm, 4000rms at 1ohm)
6. 1xHofonics genx4 maxximus dual mono(2x3000rms at 1ohm)
7. 2x Esx-se7000d (1x3500rms at 1 ohm)
8. 2xKicker zx2500.1
9. 2xKicker kx2400.1
10. 2xDigital designs m2b (2400rms at 1ohm 14v)
As you can see alot of choice.
Not sure if its better to get 1 big amp or 2 of the smaller ones.
Any info or advice would be highly appreciated.
My electrical is pretty good. Have a 300amp alt already waiting to be installed.
Car is a subaru forester.
Im not doing a wall.
Thank you in advance for any input.
Thanks for your reply. Which of the 2 would be better? Do i get the 2 smaller ones or the one big one? And what makes the gzpa a better amp than the others? I mean i love the look of the ground zero amps. But just curious.
If those are your only options listed, than I would go with the two ground zero 4ks more power and if one amp blows than you still have another amp to get you by until you can get a second one again. Plus if you can get dd audio I would just do a dd m5 or two m4s. What's the the sub's coil configuration? What's your goal with this aetup ? And how many batts. Are you working with? We need more info to help you properly decide.
I'd go with at least 6k power for the Mayhems I ran 5k each to mine when I had them and they took the power just fine. But you'll need a good electrical foundation
Id do the larger amp. they are ****** amps!
Sweet thnx guys. Yeah those r the only options i can find in holland. The 2 groundzeros sound good. But so does the big gzpa. I really appreciate the input.
About my electrical
I have a mechmann 300amp alt.
2x trojan J185 agm batteries.
Big 3 upgrades.
0 gauge wire all
2 x 1ohm subs to a 1 ohm final load.
Compete once a year. But mainly a loud *** mofo daily driver.
Im going to start building the box soon. Will post pics once i start.
And now someone has just told me a bout b2 audio he can offer me a b2 audio zero.7 (supposedly about 8000rms at 14.4v at 0.5ohm)
But not sure if b2 audio is better than ground zero. ****. Im so confused
LOL. Ya man. Its been busy. Im off today, but got stuff to do around the Casa.Be a Great sub man, and very nice amplifier. If you can swing a few...
18
Probably...really depends on the length of the run though...the longer a wire gets the lower the carry capacity gets (at least from how I...
207
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
411
Kenyanbasshead
Nairobi
Kenyanbasshead
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
