Amp choice help!
  • 2
jrmax
oklahoma
I am preparing to push a pair of 12s solobaric,perfects,eclipses,rockfords well you get the point havent decided on subs but the amp will need to push at least 500watts per sub at 4ohm probably going to run at 2ohm though if possible just give me a few suggestions only amps i know are quality are kicker and rockford!
the kicker zr600
would make good choices the zr600 also has
plug in modules (swx) so you can send a low pass
signal to you subs the zr600 is stable into
2ohm mono or you can use the dx700
the dx 700 is a sub amp that is stable to
2ohm mono it also has a plug in module (swx)
so you can send a lowpass signal too your subs
Hmm there's a few good ones. Here's a few class D monoblocks I found on the net.
MTX 81000D ~ $425 (rated @ 1000W but judging by the tests on the 6500D its nearly double)
MTX Thunder 6500D ~ $319 (tested 889W @ 14V/735 @ 12V but 984W on a speaker and 65% efficient)
Crossfire BMF 1000D ~ $465 (tested 1233W @ 14V/1013 @ 12V and 73.6% efficient)
Lanzar Vibe 1200D ~ $280 (tested 1262W @ 14V/1007 @ 12V and 67% efficient)
Rockford BD1000.1 ~ $440 (rated 1000W)
Ultimate DD1-1200 with free RF cap ~ $430 (rated 1200W and over 80% efficient)
Harrison Labs AE-800 ~ $350 (rated 800W)
LOL. Ya man. Its been busy. Im off today, but got stuff to do around the Casa.Be a Great sub man, and very nice amplifier. If you can swing a few...
18
Probably...really depends on the length of the run though...the longer a wire gets the lower the carry capacity gets (at least from how I...
6
117
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
297
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
304
jrmax
jrmax
oklahoma
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
