AMP CHOICE?? or amps?
  • 2
Only The Best
texas
ok so i just built a new fiberglass box that is molded to the roof of my dodge ram 1500 2005 and it has 2 100 rms 6x9's, 2 500rms (supposedly) audiofile supertweeters, and 1 8 inch kicker cvt sub. i am wanting to maybe include the 2 5 way kenwood 110 rms 6x9s in the front in the mix. i have an old p300 rockford fosgate that can run the 8 inch but what for the tweeters and 6x9s? i also have a crossover that i could throw in there...
P.S. i have a second battery in the back wiring not a problem.
i am not wanting to drop more than 180 on an amp, so whatever i can get that will push what i have hard, i want.
depends on impedance of the speakers , sounds like you want to run actice ,so you ned at least a 4 channel ,run the 6x9s on 2 channels in stereo at 2 ohms and the tweets off the other 2 at 4 ohms . ii can do a american bass ph 3100 for 170 shipped new .ask some of the other vendors here also
LOL. Ya man. Its been busy. Im off today, but got stuff to do around the Casa.Be a Great sub man, and very nice amplifier. If you can swing a few...
18
Probably...really depends on the length of the run though...the longer a wire gets the lower the carry capacity gets (at least from how I...
200
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
396
6
490
Only The Best
Only The Best
texas
Only The Best
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
