amp clamping vid
  • 4
Errr.. well, you really should be using true RMS meters... Unless you've got a couple nice Fluke meters (or equivalent) I wouldn't waste your time...
Also, why did you multiply the voltage by two? You should have had the same voltage on both channels. Assuming you did have true RMS meters the calc. should have simply been 30.5V x 10.7A...
Finally, what most people don't understand is that even with true RMS meters you will not be measuring the 'true power' unless you have the amp hooked up to a non-inductive dummy load... what you are measuring with the amp hooked up to a speaker or sub is the apparent power which is in Volt-Amps (or VA)... THAT IS NOT THE TRUE POWER IN WATTS...
All noted. The only thing I wasn't sure on was the if I was to multiply voltage. Ill probably note that somewhere
I prefer to measure power like this:
Fluke Meter - AC measurement on amplifier output
Crapsman meter - DC voltage on amplifier input
Oscilloscope - to measure clipping
Edit - I also used these:
and this was the final impedance of the non-inductive dummy loads:
^ where do you get .66 from ?
Gunz, those are some nice resistors... but you need a bucket of oil, and a clamp meter!!
I've got the Velleman HPS40... but what is better is a laptop and jig setup to run speakerworkshop...
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
110
6
354
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
657
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
477
thegreatestpenn
lazy genius
thegreatestpenn
columbus
Haunz
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
