Amp cuts out
  • 2
rnkelly
Good day,
I have a Viper 400.2 amp and have run into a problem.
At first one of my speakers would cut-out randomly (perhaps when I went over bumps), after some investigating I eventually localized the problem to the amp itself. I wasn`t able to find any immediately visible problems with the amp but found that the other channel worked just fine, my solution to this problem was to run mono sound to the working channel and to just conect both r+l speakers to that channel. This barbaric solution lasted for a few months but now I have run into the same exact problem with the remaining channel. I have confirmed that this is indeed an amp problem as I have swithed out the amp with a known serviceable one and the problem goes away. The cutting out gets progressively worse with time just like it did with the first channel until it just doesn`t work at all.
Have you heard of this happening before?
It seems strange that this problem would happen to both channels, almost like a defect?
Any solutions?
My other amp viper and want to keep them matching for appearance.
Any help is much appreciated
Thanks,
Ryan
183
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
384
6
483
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
770
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
559
rnkelly
rnkelly
quebec, canada
GrandPrixDriver
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
