Amp Drainage
  • 2
ltllloyd13
CarAudio.com Newbie
Hello my name is Tyler Lloyd I have a 2002 Arorua Oldsmobile 3.5 With Bose my battery was draining and a mechanic said my amp was draining my battery when my car turned off but it is a factory amp ? I don't understand how can I fix this ?
Don't expect to have much help in the classifieds.?
If he's a 100% sure it's the amp; just pick one up in a junkyard and switch it.
188
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
388
6
486
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
773
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
562
ltllloyd13
CarAudio.com Newbie
ltllloyd13
marc2112
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
