Amp dyno dynamic power.
  • 5
I actually put a dudes amp on the bench, hooked to the Oscope and DMM and ampmeter, and showed him the diff, between a cheap amp, and a good amp. He told me I didn't test them right, because I didn't turn the gain all the way up on both and take a measurement. That's the only way to compare them fairly he said ..... Some people just don't get it man ....and likely NEVER will. I mean, I showed him the wave, and tried to explain it to him even ...
He still thinks that his SSL 1000 watt amp, makes more power than a modded MMats D300 ......//content.invisioncic.com/y282845/emoticons/suicide.gif.a649d21efc0d1fd4890a6428166586c1.gif
208
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
411
6
493
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
785
LosIsATool
LosIsATool
Pensacola, Florida
Jes 42
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
