amp for 2 re se
  • 3
for 300 i'd probably just check classifieds every now and then to see if you can get anything 1200+ x 1. maybe look into a hifonics amp.
Two subs, same issue, two LOC's same issue, seems to me that there is an issue upstream. Have you tested the amp disconnected from the signal...
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
298
6
450
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
737
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
537
plopy
plopy
Indep, MO
CJW
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
