Amp for 2 Soundqubed Super tweets
  • 4
justice66
What amp would you guys recommend for 2 SQ super tweeter? I have 4 of their Pro audio Mids running of a Eclipse 34601 and I want an amp for the tweeters instead of running them of the headunit.
Also since I have 3 sets of outputs on the head unit(sub, front ,rear)can I split the RCAs running to the 4 channel so I have a dedicated set for the tweeter amp?
Thanks for any input
those things get stupid loud on low power ..u might wana try them on hu power first ..trust me i have the pa mids n tweets
Thank for the suggestions. I will check out that US acoustics amp in a minute and I was looking for an eclipse amp that's the same style as mine but cant seam to find what the smaller version is.
Thank you for your input. How many mids do you have? Im not sure how much power I will be putting on my Subs yet. I have 8 VVME 10s im trying to figure out how to fit them all in the back of my civic wagon. But I cant find a HO alt that will fit. So I will be doing lots of small batteries hopefully and around 2-3k.
4 mids 1 pair of tweets
Thanks again for the help everyone, but I got one last question. On the tweets their is a capacitor on one the of leads. Now I know this is effectively the cross over or a filter fort the tweet. How exactly am I supposed to securely connect this to the speaker wire that 14g BTW? Its just a little flimsy wire that's gonna be wiggling all the time. I might just be over thinking it. I also was research this before I posted and found this.
Capacitors in Series with Speakers
Now according to this picture I will run them in series so one tweet positive wire will go to the cap and the other the negative will be on the cap. If I hook it up just like the picture will it work and is it right/
204
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
407
6
492
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
785
justice66
justice66
Naples, Italy
justice66
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
