Amp for Skar ZVX
  • 1
Savackz
GA
I am wanting a new amp for my skar zvx. I know they can take about 3k power max and around 2.5k comfortably. I am thinking a banda 3.5k or a taramps 4k. I am going to order a 220 or around that size alternator with 270ah of batteries. Any other suggestions? I don't mind buying used stuff. Or a SQ 3500 if any up for grabs.
11
954
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
6
Recoil 2500.1 $179 2500 x 1 @ 1 ohm. Make sure subs are the dual 4 ohm version. If you don't want that much power, get the Recoil red1200.1 for 1...
4
Ill try it when I get the amp back, especially if the forbidden protect light goes on. I don't think it's grounding out anywhere because I still...
8
Disconnect all 5 speakers and the rca cables from the amplifier. Turn it on and see if it still goes into protect. If it does, bad amplifier. If...
Savackz
Savackz
GA
Savackz
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
