Amp fried?
  • 4
Rowan44
Hi guys. I have a kicker L7 powered by a kicker lx 600.1. Although the amp still runs, the protection light stays on and the amp sometimes starts smoking. I unplugged everything and tried it in another car with professional wiring etc and it happened again. I have opened up the amp and can see that the black coil looking thing has glue type stuff on the bottom on only one side (two circular donut like things on board, one has gold coiling one has thicker coiling which looks to be covered in a black sort of shrink wrap). On the other side it has gone all black and I can see it has been burnt (looks like from the underneath). Also marks on case which indicates smoke or something.
Any info on what this problem is and if it is fixable would be great. Thanks
Unless you know how to properly test the amp and repair what needs to be done yourself, itll probably be cheaper to buy a newer better amp.
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
You have a blown cap in the amp more than likely. Had the same thing happen to a soundstream amp.
239
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
444
Rowan44
Rowan44
Australia
audiobaun
Decebal
    Jun 10, 2024
