Amp gain only goes to 14
  • 2
Need help with CT 125.2 amps. For some reason the ac voltage only goes to 14. My speakers are 125 watts a piece, totally 250. I need to set the gain to 22.4 but obviously I can't. I've confirmed my other amps(non CT sounds) are set correctly. Switched rcas, power wire, remote wire between amps just make sure everything was fine. I have never had an issue like this before so any help would be great.
edit; nvm i did my math wrong
you should be getting more voltage, whats the dcv on the power source for the amp
When you say dcv on the power source I'm assuming you mean DC voltage coming into the amp from the battery? I measured with car on and in acc and they were 14.xx and 12.xx respectively. I can't remember exactly but I think it was 14.6 and 12.7. Ive heard there might be an issue with CT sounds amp only going to 14 but that was kinda hearsay. I appreciate you replying back.
I hold firm on the deposit in all situations 😎
9
  • Locked
I dont see a Username and date on any of these pics that the FOR SALE Rules Should Apply. Are these pics off Ebay?? Place those with the pics so...
Voltage for the signal? What does that mean? Electricity isn't measured in purpose. Gain is a characteristic of a circuit. You aren't adjusting...
20
6K
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
121
strawsy
strawsy
Columbus, ohio
strawsy
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
