Amp Gain Questions
What does this allow me to do then? The guy at the shop and a customer that is really good with car audio seemed to think it was a good idea. Plus I am upgrading to 2 Rockford P3D4-12s soon.
A line driver basically instead of running RCAs from the head unit allows you to tap into speaker wires which then converts the signal to one usable on RCAs.
My stereo outputs 2.5V, the line driver I am getting should allow my amp to receive 4V (Which is its max). If this is true, then I have the ability to push my amp to its fullest potential correct? So what I experience at 40 Volume with 2.5 Volts, I'll be able to experience at 25 volume? So when I get more powerful speakers I will then be able to go back to 40 volume since the amp will be capable of pushing more power, but with a clean signal still. Correct? (Yes I know those numbers aren't accurate, just more of a big picture type of deal). Or am I completely wrong? Btw asianinvasion21 that article was nice!
Did you read the article? A higher otuput voltage doesn't mean the amp can put out more power without clipping. If you're just below clipping at 200W, then you can't get more power out of it without clipping.
I did, did you? "So if your headunit is capable of 4v, and you set the amp's gains to 4v then your amp will make max power when your headunit sends it a 4v signal. Sending it anything more than 4v will cause excess distortion and heat, since you're now exceeding the maximum power rating for your amp. On the other hand, setting the gains to 8v when you're headunit's max output is only 4v will cause your amp to never reach maximum power output."
If I read this correct, then my gain should be set to 2.5V, which it is now properly set according to the proper instruments. I had the gain too high, hence the clipping. So if a line driver will increase the voltage made available to the amp then the amp should be able to supply good clean signal at a higher gain setting.
I did, did you? "So if your headunit is capable of 4v, and you set the amp's gains to 4v then your amp will make max power when your headunit sends it a 4v signal. Sending it anything more than 4v will cause excess distortion and heat, since you're now exceeding the maximum power rating for your amp. On the other hand, setting the gains to 8v when you're headunit's max output is only 4v will cause your amp to never reach maximum power output." If I read this correct, then my gain should be set to 2.5V, which it is now properly set according to the proper instruments. I had the gain too high, hence the clipping. So if a line driver will increase the voltage made available to the amp then the amp should be able to supply good clean signal at a higher gain setting.
You had it too high, in a sense. It works the opposite of how you think it does, the higher you turn it up the lower the voltage it's set at, so it will be more sensitive. You're not reading it correctly, once you've achieved max output, that's it. You can't get anything more than max safely.
Okay, okay. I think I see what you're saying. My head unit outputs 2.5, so I set my gain to 2.5 volts. So if the amp has 4 volts available and the gain set to 4V (Which is the minimum for my amp) this means that the amp will be outputting full power, but having to work less hard (in a sense?) and have less distortion (cleaner signal)? This is provided that the line driver allows me to output at 4V. If not, I can always rely on the 2.5V from my Headunit (without the driver) and still get maximum power output with subs?
EDIT: I would imagine that my current gain is set less than 2.5V, because if I can play at 40/50 Volume right now there is no way my subs should survive that. They are rated at 200RMS. The way they are wired they could get up to 400W RMS each.
No, either way the amp will be the same efficiency. Not to forget RCAs put out a much higher quality signal than your average line driver. You only have 1 option to increase power- get a new amp.
But won't sending the amp a 4V signal and having the amp gain set to a 4V gain will allow it to produce a cleaner signal? (If not then why?) Than that of 2.5V? I feel like we're on different pages trying to ask/explain things haha
The voltage doesn't determine the quality of the signal, the source determines both of them. RCAs will always have a higher quality signal than line drivers.
If the gain on my amp matches the voltage of the preamp outputs, I will get max power with a clean signal? So 2.5V output with a 2.5V gain will produce my rated 800W RMS @ 2 Ohm and 1200RMS @ 1 Ohm?
Jesus, what amp is this? If it's threshold for clipping is 200W it can't be good...
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
You have a blown cap in the amp more than likely. Had the same thing happen to a soundstream amp.
I hold firm on the deposit in all situations 😎
9
  • Locked
I dont see a Username and date on any of these pics that the FOR SALE Rules Should Apply. Are these pics off Ebay?? Place those with the pics so...
Voltage for the signal? What does that mean? Electricity isn't measured in purpose. Gain is a characteristic of a circuit. You aren't adjusting...
20
6K
fatboytyler
fatboytyler
Easternl Kentucky
T3mpest
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
