amp has power but sub dont play?
  • 4
sq_joshua
I was playing music not even loud then all of a sudden my bass cut off i checked my amp and it still had power and my fuses are not blown but if i play music you could feel the sub playing but doesnt play normal as it should u could just feel it playing even tho i put the gain up and i took my sub out of the box and looks fine. What can it be.?
In addition to checking the coils with a multimeter, check the ground for the amp. It should be bolted snuggly to unpainted metal. Also check the RCA connections to make sure they're good.
Check your remote line or RCA, some decks have written remote 2 times different wires one solid blue one blue and white, some do the misstake...
10
3K
6
174
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
416
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
378
sq_joshua
sq_joshua
los angeles
sq_joshua
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
