Amp Help
  • 3
Jim07
I never hook up an amp like this and want to make sure it will work. I have a Zapco Ref 200.2 amp. It shows I can bridge a sub and hook up the full range speakers. If I can do this, it sure would make things easy with one amp. Zapco says full range 2 ohms and the sub 4 ohms. I have a set of Focal 165 A1 and they're 4 ohms I think. I also have an older 10" Kicker Comp VR and I think this is 4 ohms. Can I hook up the Focals and bridge the Kicker? Next question is will it even sound good? Thanks
i can be done but it will have no adjustability between sub output and speaker output. I would just look into getting a sub amp and run two amps
11
969
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
6
649
Jim07
Jim07
Trophy Club, Texas
CrossoverOre
Decebal
    Jun 10, 2024
