Amp/Hu question..
  • 2
MaddMike740
27
Ohio
I just hooked up an amp the other day...all im powering is (2) 6x9's and (2) 5 1/4 inch door speakers.
On my HU i have 3 sets of rca's and in my options on the HU there is a setting for SUB -10 - +10...well if i crank up that SUB setting my rear speakers get louder...does this mean i plugged my rca's into the sub out instead of the rear out? Does it really matter cuz i mean it all works. However if memory serves correct when I adjust the FADE to the rear im thinking my speakers drop out..i'll have to check that on my lunch break.
edit: i check my fader and if i adjust it all to the front speakers i still get sound out the back speakers...lol.
if anyone cares i did some checking and looked at the instructions to my HU and i actually do have my rca's plugged in correctly...i have a setting in the options for...sub/out or rear/out. i changed that setting to rear/out and all is cool now. however i'd like to thank everyone who took the time to reply and help me out with this issue, your help was greatly appreciated. //content.invisioncic.com/y282845/emoticons/moon.gif.9d317aec3339ffe7fde0638df52c628a.gif
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
678
Hell... Run It.. You will be ok @ that Ohm load(2.67). Just dont go below 2ohms and you will be fine. 2ohms is the lowest stability of that...
5
If you do use speaker baffles.. I recommend the plastic ones rather than the foam ones, and drill a 1/4" hole at the bottom of it in the back for...
9
Haven't 100% landed on which one, but I am down to those two
12
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
8
MaddMike740
MaddMike740
Ohio
MaddMike740
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
