bob1122
Hey, I am new to CarAudio's forum's and thank you In advance for any help!
I recently installed some rear speakers in my 92 Tercel and have noticed they are missing allot of power that they had in my previous car. I happened to have a buddy with a small extra amp he didn't need so I grabbed his Rockford Fosgate Punch120a (60 x 2 watts rms) and I would like to install it but have no idea how to go about doing this. (I assume the lack of power is because all I did was connect the speakers and have no increase the power going to them.
The inputs on my amp are as follows:
Left Input (RCA)
Right input (RCA)
High level Input (Have no idea what the connector is but it have R+R- and L+L-)
REM (Just a single prong)
Then I have the output:
Left +
Left -
Right +
Right -
B +
GND
To start I assume I run a heavy guage wire from the pos terminal on my battery to the B + on the amp. I have no idea how to connect the input (Possibly solder rear right and left to RCA plugs respectivly? ), and where to run the ground wire. I also don't know what the REM is for and if its neccesary. There is also a Switch (120HP - full crossover- 80LP), Is there a specific setting I need to use?
I am still using the stock radio is this going to be a issue (I plan to upgrade when I can afford too!)
Thanks allot for any help !
Left Input (RCA)
Right input (RCA)
Left +
Left -
Right +
Right -
B +
GND
