Amp is getting power but sub is not hitting?
  • 3
I am by no means skilled in car audio or electronics, I have done my best reading forums and various car audio problems I have ran into the past few years. So sorry if this is a noob question, but I am stumped!
I have a Jensen Power 760 amp and a 12in Kenwood sub.
My amp has the power light on and the protect light off all wires are hooked up correctly.
Been using this setup perfectly for the past two years. The other day the sub just cut out, I figured just a loose connection. Have tested ground and power with DMM everything checks out. So I decided to check the RCA's I only got about .2-.6 volts is that normal? It is also the same when I checked the output of the HU meaning it is not my RCA wires. So I have concluded that it is either my HU or my amp is just dead. (deff possibly it is old and not high quality)
Any help or tips would be appreciated.
Sounds like either your speakers or your output fets on the amp take the speakers out the box check the connections if there in tact , take the speakers and hook them up to a house stereo if they work its the outputs on the amp
Go 150 Watts speakers or equal to your amps. 150 watts and up is your amps. That's the good rule of thumb.
12
125
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
326
6
458
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
747
matts_pyro
matts_pyro
Jacksonville, FL
Nutdawg651
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
