Amp issues...
  • 4
OmegaBunny
Moderator
Ok here's what happened...
Wednesday I hooked up my amp and sub. The amp was a brand new SoundStream Rubicon 2500D. I turned the stereo on, and everything played fine. I drove around for about an hour and everything was perfect. The next morning, about 16 hours later, I went out to start my car and it was dead but the amp was still on. When I would try to turn the car over it would thump once like the amp was trying to turn on. I took out my keys and the amp still would not turn off. I pulled the remote wire and it was still on. I removed the fuse and it shut off.
That evening I reinstalled the remote wire and the fuse and it wouldn't turn on. I check the poser and ground at the amp and it was reading 12.8 but the remote wasn't reading anything. I checked the remote at the HU with it disconnected from the amp and it was reading 12/14 with the car off/on. I hooked up the remote up and it read -.8 I ran a different wire and it did the same thing. I tapped into a different source and it is still reading ~ -.8.
What could be going on?
I had a soundstream picasso amp that would stay on no matter what, as long as the power wire was hooked to it, it stayed on, even without a remote lead. Good amp, but drained my battery. My friend had the same amp with the same problem. I don't know if this is a similar problem with your amp, but it sure sounds like it. Maybe try jumping a small wire from the 12v on the amp to the remote and see if it kicks on? Then youll know its your deck or remote or not. Might have to send it in for repair
Id send it in under warranty repair,waste no time with that, and get another amplifier that would be reliable rather than having issues.Just what Id do
Made a jumper from the + to the remote and it kicked on so I tore my dash apart and ran a new remote wire and everything works fine. No idea what happened but I'm not going to complain since its working. I checked everything about a dozen times and it turns on and off, and plays fine.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
With the remote wire out. Make a jumper from the amp's power to the amp's remote terminal. If it turns on then the amp is ok. If not then the amp...
786
Did you consider using the PAC AmpPRO 4, AP4-CH31? It will connect between factory amp and head unit and allow you to have RCA outputs for the amps.
5
Do you have about $100 to waste? Try a cheap amp that has line-level inputs, see if that helps. WalMart carries a 4 Channel Jensen amp, for its...
8
OmegaBunny
Moderator
OmegaBunny
Keyser, West Virginia, United States
OmegaBunny
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
