Amp issues
  • 4
The ground is self tapped to floor of tahoe
You may need to find a more secure ground location.Self tappers are usually not very secure for a ground and usually a poor source on sheet metal. Find a bolt that that is more towards the frame section of the vehicle and utilize that with washers and a terminal ring cleaned from paint ect.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
With the remote wire out. Make a jumper from the amp's power to the amp's remote terminal. If it turns on then the amp is ok. If not then the amp...
789
Did you consider using the PAC AmpPRO 4, AP4-CH31? It will connect between factory amp and head unit and allow you to have RCA outputs for the amps.
5
Do you have about $100 to waste? Try a cheap amp that has line-level inputs, see if that helps. WalMart carries a 4 Channel Jensen amp, for its...
8
Slow1019
CarAudio.com Newbie
Slow1019
Arkansas
audiobaun
Decebal
    Jun 10, 2024
