Amp keeps going into protect?
  • 3
LivinLoud08
Banned
210
Alabama
Both amps are powered by 2 kinetics each (in sig) but for some reason at high volume one of my amps will go into protect(mostly on the very low notes). Im just curious as to why only one would do this and not the other as well since they are both set up the exact same? Any suggestions on fixing this problem?
it comes tomorrow and i cant wait. Thanks for spotting that amp and recommending it!
19
4K
142
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
334
6
464
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
751
LivinLoud08
Banned
LivinLoud08
Alabama
LivinLoud08
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
