Amp kill switch help. 4 Pin Rocker?
  • 3
No reason why you couldn't. It's not really the best use for that particular switch, but it's not going to harm anything.
I always used a switch to control a relay for the amp, but thats a personal decision.
Double Pole Single Throw (DPST) Switch
Also, the switch itself should have a wiring diagram embossed on it telling you how to hook it up. Looking at the page you posted, it would appear that the switch doesn't have a ground, just 2 inputs, 2 outputs.
A standard SPST (or 2 pin as you say) would be more appropriate.
I always planned on installing switches in the remote to the amps to shut them down when I want to. Admittedly I’ve never gotten around to it. An...
6
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
You have a blown cap in the amp more than likely. Had the same thing happen to a soundstream amp.
235
Jaren
Jaren
Tacoma, WA
huberoy123
Decebal
    Jun 10, 2024
