amp kit?
  • 3
Being owned by the same parent company doesn't make them both RF.
The LA kit uses a 150A fuse and isn't specified as AWG -- they use the generic "gauge". The LA site says true spec AWG SIZE -- which probably means it's CCA, but has a reduced current capacity because it's OFC sized 1/0.
RF is OFC with a 300A fuse.
Have you check to see if the prefab would fit...
13
I dont remember one recently. The kit is a fair enough price for what it comes with IMO
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
107
6
352
gozaine
gozaine
LARA
n2audio
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
