Amp location in 2000 F150 supercab
  • 2
lariat flareside
se usa
I am looking at buying a prefab box (https://www.supercrewsound.com/00F150ECdual.html) and running 2 kicker Comp VX 10’s at 4 ohms. I’m sure it’s right in front of my face, but I blatantly cannot understand how Amps work. So my question is what amps could I run to power both of these to the best of their limits? Should I do a vertical mount or will under the front seat be fine? I was contemplating a kicker amp to match the doors and subs, is that the right choice or are there better amps for the same price range? I know that’s a lot, thanks in advance.
For a basic system the kicker amps should be fine...
How much power from an amp would I need to get the most out of both of those subs? I was looking at a kicker cx 1200.1 which has 600 watts/ch and matches the specs of the subs perfectly. Is there any difference when running 2 subs to the same amp? Thanks.
I agree…not a very good install. Hopefully you didn’t pay much (hopefully it was free). Get your DMM (or find someone who has one) and find a...
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
You have a blown cap in the amp more than likely. Had the same thing happen to a soundstream amp.
245
lariat flareside
lariat flareside
se usa
lariat flareside
Decebal
    Jun 10, 2024
