Amp malfunctioning, anyone know what may be problem
  • 3
nate1017
Okay a few days ago my sub quit hitting and i noticed bass would kick on for a split second when i hit a bump or took a turn fast. So when i got home i started to tinker with it and realized if i pushed down on mid lefthand side of the amp it would begin powering my sub again. Anyone know why this might be happening? Should i take my amp apart to see if there are any loose connections? Any help would be appreciated......btw its a Rockford Fosgate Prime 500.1
don't take an amp apart unless you already have experience with electronics repair.
yes, a loose connection is likely but a novice can do more harm than good.
until it's repaired, you want to disconnect it. intermittent signals may cause arcing which will cause a fire.
No the power light stays on just doesn't power the sub.....also how much a repair on this might cost? just wondering may just end up buying new amp
Two subs, same issue, two LOC's same issue, seems to me that there is an issue upstream. Have you tested the amp disconnected from the signal...
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
317
6
454
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
743
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
542
nate1017
nate1017
DeFuniak Springs Fl
nate1017
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
