Amp powering on but fading off please help!
  • 1
Colt198
Hey I've been running my 2 jbl 12" subs for a solid 5 months perfectly fine but then all of the sudden it cut out, when I put the remote wire into the remote input it will turn on the amp for a second but then the amps power fades away and turns off within a couple seconds I've already tried changing the remote wire out and still it had the same outcome.
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
856
The 750 will give you better control at higher volumes as you won't be reaching clipping as soon..
6
I would pull the amp and bench test it with power and ground wires. If it still doesn't power up, its probably shot. My next step would be to...
187
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
388
Colt198
Colt198
Minneapolis, MN
Colt198
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
