Amp protection: What is DC protection?
  • 4
phantom240
ALL YOUR INTERNETZ
I think my budget Zapco ate **** this week, just as I was about to replace my front stage due to a blown tweeter with no suitable replacement. Looking at a new amp, I'm seeing most amps have three protection modes: Short circuit, thermal, and overload. However, my current amp also has "DC" protection. What exactly is that?
lol.
So if I'm understanding correctly, DC protection would come into play in the event a MOSFET, or reed switch, gets stuck in the closed position, correct? I'm trying to figure out why my amp is shitting itself going between operational and protect in three second or so intervals, and I know it isn't thermal because it was only 75 degrees according to my infrared thermometer. It wasn't a shorted speaker, as I disconnected them all in my attempts to find the problem. With the amp completely disconnected, all my channels are reading around 4.75k ohms. And there's nothing obviously damaged on the board.
Short of it (pun, ha) is the amp has DC on the power inputs and converts and outputs AC to the speakers... so you dont want DC in your speakers.
Hmm well I can scratch that off my list then. Well, ****. I really don't wanna send this thing out for repair, but driver circuits on class D amps requires equipment I don't have access to.
Ok thank you, I'll check where the remote wire is connected and get back to you.
Ill try it when I get the amp back, especially if the forbidden protect light goes on. I don't think it's grounding out anywhere because I still...
8
Make it look nicer. Carpet it up with black. It will look like a speaker. The wood look is not good at all. Don't look too professional. What...
39
6K
Disconnect all 5 speakers and the rca cables from the amplifier. Turn it on and see if it still goes into protect. If it does, bad amplifier. If...
Not much user serviceable about an amp powering up into protect with nothing else connected. Send it back for repair/exchange or whatever they do...
phantom240
ALL YOUR INTERNETZ
phantom240
Southeast Louisiana
phantom240
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
