Amp question
  • 1
Dawgggk
I am fairly new to car audio, so this doesn't always make sense:
I have 2 Rockford Fosgate shallow r2s I'm about to order. I already have the box.
My main confusion is the OHMs, and what wattage amp I would need.
I can either grab two 2ohm subs or two 4ohm subs, what is the difference? Which would be better?
What wattage amp would I need for the two 2 ohms, or the two 4 ohms? Mono block would work for two subs, correct?
Someone please explain to me what I need, and why I need it. Thanks.
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
760
Hell... Run It.. You will be ok @ that Ohm load(2.67). Just dont go below 2ohms and you will be fine. 2ohms is the lowest stability of that...
5
If you do use speaker baffles.. I recommend the plastic ones rather than the foam ones, and drill a 1/4" hole at the bottom of it in the back for...
9
Haven't 100% landed on which one, but I am down to those two
12
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
8
Dawgggk
Dawgggk
Albany, GA
Dawgggk
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
