Amp question
the amp I have now is a 2 channel so the car is wired for that should I stick with a 2 channel or rewire it for a 4 channel? does it matter class d or a?
760
Hell... Run It.. You will be ok @ that Ohm load(2.67). Just dont go below 2ohms and you will be fine. 2ohms is the lowest stability of that...
If you do use speaker baffles.. I recommend the plastic ones rather than the foam ones, and drill a 1/4" hole at the bottom of it in the back for...
Haven't 100% landed on which one, but I am down to those two
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
floridaguy727
floridaguy727
arkansas
floridaguy727
