Amp reapair
  • 1
Dblee
I'm trying my hand at rebuilding and fixing amps my question is where would I buy Transformers and which one should I buy are the bigger ones more powerful ones or what what should I look for and if I put bigger Transformers I'm sure I have to put higher voltage caps in there right
150
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
347
6
466
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
752
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
550
Dblee
Dblee
Richmond va
Dblee
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
