Amp Recomendation
  • Thread starter <ricweb>
  • Start date
  • Replies 2
  • Views 1K
  • 1
<ricweb>
Guest
I am thinking of uping the power on the mids and highs to 125 watt/channel. Any recommendations on how big my sub amp should be ?? I am only running a 10" in a sealed enclosure. I had always heard 3 times the power up front. Any suggestions ??
The sub I am running is a Alpine SWR-1040D, my current system has a Rockford 600a5 amp 50x4 and 200x1 at 2ohm.
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
You have a blown cap in the amp more than likely. Had the same thing happen to a soundstream amp.
227
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
430
Guest
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
