Amp recommendation 2xSA8 V1.5
  • 4
BLK MAJK
Looking for some amp suggestions for my new setup. I think I have a short list of amps, so I'm just trying to make the best decision. I recently got a pair of Sundown SA-8 V1.5 subs. These are the 400w RMS models. Dual 2 ohm VC. I plan on wiring them to a 2 ohm load. I'm thinking I want/need an amp that does 1000 RMS @ 2. Car is wired with Knuconceptz OFC 4 gauge. Amp is getting signal from a LOC (want to keep my factory nav) wired into factory sub (its unhooked). Car is a 2012 Kia Optima with the factory Infinity stereo. I will be building either a shared box, or 2 boxes (1 in each wheel well "bumpout" in the trunk). Either setup will be ported. Just looking for a daily driver setup. Budget is $200 so I'm looking at used. So far my list has the following.
Alpine MRP-M1000
Hifonix BRZ1200
Boston Acoustics GTA-1000M
MB Quart ONX1.1500D
Kicker DX1000.1
JL AUDIO JX1000/1D
Soundstream Rubicon 1600
Any other suggestions? I know I have seen the Audioque 1200D mentioned as well but I'm not seeing any of those around used. Thanks for any help!
189
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
389
6
486
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
773
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
562
BLK MAJK
BLK MAJK
United States
na_rsx
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
