Amp Recommendation
  • 4
Alpine R-W12D2?.. hows your enclosure look and what are you lackng?
Even on a cheep azz hifonics.. if the enclosue is on point your system should perform.
Me thinks the box is the issue as usual.
This forum is turning into a shitshow imo
Well if the amp is 1200W x 1 @ 2 ohms and the subs are a combined 1500w RMS @ 2 ohms, then wouldn't they be under powered by definition? I could be wrong about how I'm looking at that though. I'm not sure if just getting another amp is going to solve your problems...it may make more problems.
Did you have a budget in mind?
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
You have a blown cap in the amp more than likely. Had the same thing happen to a soundstream amp.
243
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
452
RedVenom
RedVenom
Missouri Valley Ia
focused313
Decebal
    Jun 10, 2024
