Amp Repair People
Since I work in sourcing in the professional audio field, I can say that we buy Fairchild, IR, On-Semi, Vishay, NXP and Diodes Inc parts. There are a variety of other vendors but our spend with them is insignificant.
Several of those brands don't sell directly to customers unless they represent very large demand streams. You can try contacting Avnet or Arrow for distribution access inside the USA. I try to avoid distribution accounts because they add costs without adding value, but if you are trying to source for a one-off job, they might help.
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
193
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
389
6
487
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
778
cfox10
Rock the house.
cfox10
Tillamook, Oregon
cfox10
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
