Amp setup recommendation
you need a 3 channel or a 5 channel amp. You cannot do it with a 4 channel amp with that subwoofer because when you bridge a 4 channel amp, the lowest ohm load it can go is 4 ohms. Your subwoofer being wired to 2 ohms will fry the amp.
I don't think my sub has to be wired for a 2 ohm load, it can be run in either 4 ohm or 2 ohm load. Are you suggesting it's best to run it in the 2 ohm load though?
no. you need to check properly and find out WHAT ohm your sub really is.
a 4 ohm Dual voice coil subwoofer can only be wired 2 ohms or 8 ohms
a 2 ohm dual voice coil subwoofer can only be wired 1 ohm or 4 ohms. Check again.
no. you need to check properly and find out WHAT ohm your sub really is.a 4 ohm Dual voice coil subwoofer can only be wired 2 ohms or 8 ohms
It is a 4 ohm DVC. So I guess it can only be wired for 2 or 8 ohms. Since that is the case then if I wire those 2 channels on the amp from my earlier example for this 8 ohm load will that be safe?
yes that will be fine you'll get very little output unless you have a very beefy 4 channel amp though. Keep expectations within reason and you should be happy. It wont shake anything but it'll reinforce the low end of the spectrum.
I will look into the big 3 being done here pretty soon. As I said previously you guys are awsome, so thank you for everything. My alpine's came...
10
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
124
6
360
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
664
ShaithMaster
ShaithMaster
Sacramento, CA
kahlilj
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
