Amp showing different DMM readings on each channel
  • 2
jxkey
Alright so short and simple
Tuning my amp gains with a DMM.
Need 28.28 for 400 RMS per sub.
Running 2 4ohm DVC Hifonics subs to 2 ohm load on 2 Channels on an Arc Audio FD 2200.
I can get one channel to 28.28 but the other channel is reading 16 - 19 and I'm trying to figure out why. Maybe someone here will have some insight
I am using a stock headunit with a LOC. (stock headunit is a double din and it sounds clean with my added soldered AUX input)
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
You have a blown cap in the amp more than likely. Had the same thing happen to a soundstream amp.
230
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
433
jxkey
jxkey
Greenville, SC
jxkey
Decebal
    Jun 10, 2024
