Amp Shuts off at medium volumes PLEASE HELP
  • 3
qwerpoo
I do not know much at all about cars or car audio systems so i apologize if i am a hassle. Recently for Christmas i got/installed a sub into my car. It works perfectly fine until i turn up the volume a little bit. If i turn up the volume my amp starts flashing blue and the sub stops bumping. I think it is going into protection mode. How do i stop my amp from going into protection mode at medium volumes?
without a full system description, info with model numbers, amp settings, enclosure specs, vehicle, head unit..... ETc.... We cant help you without any proper detail.
Its the same thing as asking someone uuuuh my system broke how do i fix it over the internet.... It just doesnt work that way.
The amp may not be properly matched to the sub. And like this guy ^^^^^^^^^^^^^^^^^ said....with out the proper information,hard to help ya out.
yall. I unplugged the radio harness and the antenna and plugged it all back in and it works. I guess its fixed… suppose it was the head unit...
853
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
128
6
363
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
665
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
481
qwerpoo
qwerpoo
Missouri
pickup1
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
