amp static
  • 3
rockyrocker
so i posted this in the speaker section but i think it would be better here. i think i have an amp problem. with my amp out of the car on the kitchen table running off a car battery with two 8 inch 4awg wires running from negative to battery negative and positive along with a 22guage remote wire to the positive battery terminal. i hook all those connections up clean and tight and plug in a tweeter and i get crazy static. i turned the gain up and down and it changes with the sound. this amp is a jl audio xd1000/5v2. and i also did this on a mono sub amp (jl audio jx 500/1d) and i got the same static. i have brand new rockford fosgate wiring. i would appreciate any help i could get.
You should post in general discussion section.
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
170
6
395
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
704
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
512
rockyrocker
rockyrocker
Birmingham AL
rockyrocker
