Amp stops sending signal to new speaker installed in Jeep JL
  • 3
jollycj
CarAudio.com Newbie
I recently installed a new Morel CCWR254 2-1/2 Midrange in my dash to test out for a left dash speaker, it can function as a midrange/tweeter. It replaced a Kenwood Excelon KFC-X3c Coax that worked fine, see pic. Have the other Kenwood still installed in the right dash and it works fine. Its installed in a 2021 Jeep Wrangler with the base 7 inch stock unconnect radio.
The Morel worked fine for about 15 minutes and stopped working. I pulled the fuse and reset the radio and the left dash speaker (Morel) started working again, but it stopped working again. It's possible it stopped working after I turned the volume up to 3/4's, not sure.
I'm novice so looking for ideas about what is causing it. No bass blockers, crossovers, or capacitors are installed with the Morel speaker. The right dash speaker is a Kenwood Excelon KFC-X3C and it works fine and the left is the Morel currently. Is it possible since the left and right speakers are different its causing the issue, different sensitivity or resistance.
Supposedly the factory radio is only sending the signal for this type of speaker and sends the bass signal the knee pod speakers.
That is probably the issue. You can play lower resistance at moderate levels, but with higher volume the strain rises on the amp section of the radio, hence protection kicks in. Does the Morel really sound better?
It sounds better in my view. What you said makes sense, eventually I'll add and amp and hopefully this will be a non-issues.
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
96
6
345
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
649
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
475
jollycj
CarAudio.com Newbie
jollycj
jollycj
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
