Amp Suggestion Jl Audio320.4 vs Focal R4280 vs jbl1004
  • 4
Bharat
I have found these Amps on classified.
I will be using them to power up Morel Maximo 5 comps (85wRMS) in front and Coax(75wRms) in rear.
options are:
1. JL Audio 320.4 60wRMS per channel
2. Focal R4280 70wRMS per Channel
3. JBL 1004 100wRMS per Channel
which one out of these should I get?
thanks
Figuring it's the old gto 1004 i'd go with that one. I don't think you'll notice a big difference between any of the amps except the jbl offers the most power
Great bang for the Buck/ Have (2)2ks and a 150.4. great amps for the Coin Thus far.A little head room doesnt usually hurt...
5
203
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
406
6
491
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
784
Bharat
Bharat
Delhi, India
pw91686
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
